PSoC 5, 3 & 1
Often i am structed by the following error
"Error-Exclusive access to ICE device 0735C465 was denied"
Pleas suggest to get rid of it
kavin
Roy_Liu
Is this article able to help you out?
http://www.cypress.com/?id=4&rID=39222
Roy Liu
RoNo_264271
Contributor II
Do you have multiple instances of PSoC Designer running at the same time? Or do you have another program running which is using the ICE / Miniprog.
You can run the taskmanager and close all "PSoCProgrammerCOM" instances and try again.
Rolf
