PSoC 5, 3 & 1
Hi again
I have a problem in size code generation. I wrote a program that occupies only 20% of flash memory, but to build,  the debug  tells me the following message: branch out of range. what will be happening?
I'm using psoc designer 5.2. I'm just using the LCD module
help please
sorry the bad inglish!
Thank you
Obrigado
Deus abençoe
correcting
what might be happening?
Bob_Marlowe
Expert II
I would suggest you to zip your project folder and upload the file here, so we all can have a look at.
Bob
Bob_Marlowe
Expert II
By the way: "Branch out of bounds" sounds like an assembly error. Are you using C and/or assembly?
Bob
I'm using assembly
Are you had similar problem bob?
Bob_Marlowe
Expert II
When you use assembly you can make errors that cause exactly your errormessage. Quite easy: you have a jump-instruction and you must use an LJMP. The JMP just reaches +- 128 Bytes (estimated).
So Why do you not use C ????
Bob
IT IS MY PROBLEM! I get this menssage also, the build request for change CALL of LCALL, Wold like of know why.
I'll try in C
thank you by answer!
Fica com Deus
Abraços
Bob thank you, your answer helped me
changed jmp per ljmp and call per lcall sucefull
abraços
Fica com Deus
