PSoC 5, 3 & 1
 hi...
       while iam trying to program my CY8Ckit-030, i am getting an error as    "There was an error while programming the device: PSoC Programmer reported error (102 - Failed to erase the flash)"....
        i am getting this error in both creator 2.0 and 2.1.........can any one help me how to rectify it.........
here iam attaching a screen shot of the build window.....
Bob_Marlowe
Expert II
Are you using the USB-Connection or a Miniprog3 to program the chip?
Any protection set for your PSoC3?
Same error (probably) for a project that earlier did program?
Also have a look here http://www.cypress.com/?app=forum&id=2233&rID=69172 although the error is a bit different.
Bob
Bob_Marlowe
Expert II
Bob
 @Bob
                 I am using USB port to program.......i tried by disabling my bluetooth setting of laptop.....but still iam getting the same errors....
 i am using the latest programmer 3.16....
earlier i was using first touch kit......now also, the programming of same to the first touch kit is happening successfully....when i try the same with the Cy8cKit-030, i am unable to program.......
ETRO_SSN583
Esteemed Contributor
Power jumpers on the board match project settings ?
Regards, Dana.
ok....thank you very much............now it is programming properly............
I am also facing these type of error in past please change use COM port or update your software to latest to avoid these errors.
