peak detector
 hi to all,
i have gone through peak detector of AN60321, but unable to find that project. can any body post that link.
thanks
It is there on the app note page:http://www.cypress.com/?rID=41001
Or click this link:     www.cypress.com/?docID=38359
 hi to all,
   how to find a peak to peak value of any arbitary wave form (say square wave) , in which we have to read positive peak and negative peak. Here i am attaching bundle, can any sugest how to use it,
thanks
Try attaching the project from IE if you are using Chrome for uploading any attachments.
 Try inverting the inputs of comparator - You would get a -ve peak detector. (above Vssa)
 hi to all,
    after using the MAaximum_peak_detector component , voltages levels are scaling down , what could be the reason for this?
thanks
ETRO_SSN583
Level 9
Level 9
The peak detector is based on a S/H module, in turn, being an analog solution, uses
charge on a capacitor as its memory. PSOC 3 datasheet for S/H does not specify the droop
rate, which is leakage caused. Q = C x V, I = C dV/dT. So if you have a leakage of 1 uA, working
with 5 pF, you can compute how much it will droop in your timeframe of concern. The way around this
is a servo loop with a DAC, or easier, A/D the peak and hold that in memory that does not forget.
Regards, Dana.
