PSoC™ 5, 3 & 1
I am using the device PSOC 5LP CYC8C5868AXI-LP035, I want to use CAN interface..for that instead of going with CAN module from Cypress I would like to use CAN transceiver IC TJ1040 from NXP..may I know which pins of controller I have to use.
ShanmathiN_06
You could use any pin in the controller. Please refer to http://www.cypress.com/file/45906/download (page 47).
Shanmathi
ShanmathiN_06
Shanmathi
