Mar 01, 2016
01:14 PM
Mar 01, 2016
01:14 PM
i cant got correct output of temperature . can anyone say me what i did wrong in this project.??
i attached circuit and project.
Labels
PSoC 1
Mar 02, 2016
02:05 AM
Mar 02, 2016
02:05 AM
How do you do cold junction compensation? Where do you measure the local temperature?
Mar 02, 2016
02:12 AM
Mar 02, 2016
02:12 AM
i will attach it later ... still it is remaining but without it...i have to got some temperature..which cant got it..
Mar 02, 2016
03:30 AM
Mar 02, 2016
03:30 AM
What do you mean you got no temperature? Do you get the wrong temp, or just none? In the latter case probably something in your code is wrong...
Mar 02, 2016
03:46 AM
Mar 02, 2016
03:46 AM
When i start the program i got the 2054 ADC reading on lcd... and if i attach themocouple then also got same reading.
Temperature reading is remainng zero.
Mar 02, 2016
03:48 AM
Mar 02, 2016
03:48 AM
is that circuit is perfect which i attached??
