PSoC 5, 3 & 1
Hi.
In my project I use FS_FindFirstFile() and FS_FindNextFile() functions in order to list the files on my SD card.
These functions return FS_FIND_DATA structure. One of its fields is FileSize.
I can't see any relation between the numbers I get from this field and the actual files sizes, which I see when I plug the SD card into a PC. According to emFile documentation from Segger, FileSize is "U32 value specifies the size of the file" (U32 = unsigned long).
Anyone else tried to use these functions?
himam_31
Can you attach the complete project
Hima
