PSoC 5, 3 & 1
        Is it possible to be able to re-program the development kit boards with the factory hex file ? (Just in case, to troubleshoot the hardware to make sure it is still operating properly.) It tests the LCD, RS-232/USB communications, etc.
ETRO_SSN583
Esteemed Contributor
What is the part number of the factory board you are using ?
Regards, Dana.
ETRO_SSN583
I see you posted in the PSOC 3 forum, using the -001 board.
Answer is yes, and hex file is here -               http://www.cypress.com/?rID=37464
Regards, Dana.
 Awesome. Thanks, Dana !
