IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
PSoC 5, 3 & 1
I download the demo file of CY3280. I try to add EZI2C into this project. but it always fail.
At last I found out that cy8c22545 run on 5.0v 24mhz(SYSCLK/1), I2C can not work. If SYSCLK/x, x not equal to 1, every thing is fine.
Please tell me why. Is there any document about this situation?
I attached a most simple file for your testing.
pushekm_21
 Hello Teddy,
Thanks for bringing up this problem. I haven't heard about this yet, let me check it out and shall get back to you.
Pushek
