PSoC 5, 3 & 1
Hi there,
I try to use
sprintf (My_String, "%f ;", longitudeDegrees);
UART_PutString(My_String);
but this doesn't work.
sprintf (My_String, "%d ;", counter);
but this one is working. i think there a problem with convert from flaot to string. I am using PSoC Creator 3.3, ARM GCC 4.9-2015-q1-update, and PSoC 5 LP.
Could you help me with this problem? Thanks
Bob_Marlowe
Expert II
Hi Peter!
Set "Heap Size" to 0x0200 (in cydwr view, system tab)
Set "Use newlib-nano float formatting" to true (in Project->Build Settings -> Linker)
This should work Creator 3.3
Happy coding
Bob
Bob_Marlowe
Expert II
Hi Peter!
Happy coding
Bob
That's working Bob. thanks so much
Bob_Marlowe
Expert II
You're always welcome, Peter!
Bob
