PSoC 5, 3 & 1
hello i need to use the lcd multi port blick ,but for some reason icant use it , u get this eror :
is this becouse the verson of the LCD mp is older then my PSOC ?
rola_264706
Honored Contributor II
Here is the program for the PSOC 5 LP Board. Pin outs have been changed for the PSOC 5LP
Bob_Marlowe
Expert II
You probably have to update the component first to get a version compatible with latest Creator. Then export LCD component into your project.
Bob
ye I thought so and i tried to update this component but i faild , how to update it correctly ?
rola_264706
Here is your program.
rola_264706
