Has anyone managed to use Creator running under Windows 10 to programme PSoC with a Bluetooth connection linked to say the programming header of a USB kit programmer.
I have already had two laptop USB ports go down from to many connections and disconnections while programming , to want to do this again.
Using the laptops Bluetooth transmitter would make life a lot safer for the computer when working on a live test kit board.
Any suggestions welcome
PSoC1 MCU
PSoC3 MCU
PSOC5 LP MCU
@odissey1 I have so far followed your advice but with an extra technical twist.
I obtained a second hand Belkin Networked USB hub, (which needs SX-Virtual Link software downloaded from the Silex website), to work with Windows 10. Belkin is no longer sold but Silex have a similar unit.
So far I have been able to wireless connect to my network and programme a USB kit in the remote networked USB hub.
Programming speed is a little slower but at least I am not plugging into the laptops USB port continually. Should the test kit I am working on send a killer scenario to the USB uint I only lose £80 against £1000+ for a high spec laptop.
I will still look into Bluetooth to USB kit type programmer but no longer as a high priority.
It would be simpler to use a powered USB port
