Hello Every one,
Resource limit: Maximum number of SC Fixed Blocks exceeded (max=4, needed=5).
I am getting this error while placing a PGA in my design.
I am using PSOC 5LP, creater 3.2
Looking forward for your reply.
Best Regards
Awais
ETRO_SSN583
Level 9
Level 9
In  workspace explorer, results tab, towards the bottom of file list is a file named *.rpt,
that shows you the amount of resources you have used.
In your case you have 1 OpAmp left which you could make into a PGA
using analog muxes and an external R network.
Regards, Dana.
ETRO_SSN583
Level 9
Level 9
Can you upload a project archive to be examined ?
Consider posting your project, makes life easier to troubleshoot.
“File”                                                             Creator
“Create Workspace Bundle”
Regards, Dana.
Yup that will be easy.
ETRO_SSN583
Level 9
Level 9
You have 4 mixers each which uses 1 SC/CT block, same for a PGA.
You have a total available of 4. Thats what is causing error.
Regards, Dana.
Oh ok .
Thankyou so much .
Awais
ETRO_SSN583
Level 9
Level 9
Regards, Dana.
Great!! its a nice feature. Did'nt know that before.
Best Regards
Awais
