07:03 AM
Aug 25, 2016
07:03 AM
greetings,
Can Someone please tell the meaning and how to solve this error ?
Signal "\WDAC1:Net_189\" is expected to connect to only one GPIO analog pin but instead it connects to "\WDAC1:VDAC8:viDAC8\". Please fix the connection
Signal "\WDAC2:Net_189\" is expected to connect to only one GPIO analog pin but instead it connects to "\WDAC2:VDAC8:viDAC8\". Please fix the connection.
project attached below.
Thank you.
Labels
PSoC 5LP
07:34 AM
Aug 25, 2016
07:34 AM
Obviously the scanning comparatoreuses an input multiplexor that must be connected to GPIOs directly.
Solution: Connect the DACs to pins and the inputs of the comparator as well, then connect the pins externally.
Bob
Aug 25, 2016
08:05 AM
Aug 25, 2016
08:05 AM
