PSoC 5, 3 & 1
pushekm_21
I'll get some of the VC++ expert to reply to your query.
Pushek
Looking at the error it seems it is not able to locate CyAPI.lib.
Are you using CyAPI.lib from the x64 folder the 64-bit platform compilation? Please check the difference in configuration between your project and the examples available as part of SuiteUSB and update here.
Anand
 Thanks, it worked..The sample application helped me to solve the problem
