PSoC™ 5, 3 & 1
There are applications that may require accurate clocking system. Especially the communication protocols may need precision timing requirements for proper operation. And it may be necessary to use an external clock, the same is explained in the followin project.
       Using External Clocks in PSoC®3/PSoC 5
