Hi all, I'm trying to create a PSoC 5LP Design and after the workspace/project is created, i cannot add any components from the component catalog into the workspace at all. By adding i mean click and drag the component into the workspace. (i'm trying to add bootloader, but every other component doesn't work either). Please help, thanks
PSoC 5LP
Welcome in the forum!
This "smells" a bit like an installation went wrong. First check for your access rights in the project directory. When these are correct, I would suggest you to de-install Creator and re-install Creator 3.2.
Make sure you have got the microsoft .Net updates first.
Bob
Sure sounds like the Creator installation hosed. Bootloader has
to be placed on top level schematic, I think the recent release
notes discuss that. But no other component, something not right.
Try first to start a new empty design, all else fails re-install.
Or try any example project, just to see if you can add components
to it.
Regards, Dana.
Access rights are Operating System (Windows). Right click in windows explorer on a folder and select properties from the menu. Under the "Security" tab you'll see what is set.
Try at first to run Creator as administrator and/or get help from a windows guru.
Bob
I have allowed full control to the creator but still nothing happens when i click and drag the components. This goes for new empty projects and existing projects.
Create a support case, someone from cypress will help you. Leave a link to this thread, your phone number and timezone.
On top of this page click on "Design Support" and then on "Create a Support Case".
Bob
Thank you for keeping us informed.
Now: Happy designing!
Bob
Just be aware, from latest release notes 3.2 SP1 OS support is -
Operating System
One of the following Windows platforms is required:
Windows XP SP3 (32-bit supported)
Windows Vista SP2 (32- and 64-bit supported)
Windows 7 and Windows 7 SP1 (32- and 64-bit supported)
Windows 8 and Windows 8.1 (32- and 64-bit supported)
Mac OS 10.9 on VMware Fusion 6 running Windows 8.1
Mac OS 10.9 on Parallels Desktop 9 running Windows 7 SP1
Hopefully you will not run into any additional problems.
Regards Dana.
You could always file a CASE and ask if there are any know issues at this time
with Win 10 -
To create a technical or issue case at Cypress -
www.cypress.com
“Support”
“Technical Support”
“Create a Case”
You have to be registered on Cypress web site first.
Regards, Dana.
