May 26, 2016
09:30 PM
May 26, 2016
09:30 PM
I have to program ten PsoC 5 chips with PSoC programmer 3.42.2 and Mini prog3
PSoC programmer fails to program 3 of 10 chips,
but Seven chips is programmed successfully.
The error massage is "Timeout of SPC polling "
My conditions and configurations are as follows,
CY8C5868AXI-LP032.
Programming Mode: Reset
Verification : On
Auto Detection: On
Protocol: SWD
Voltage: 3.3 V
Connector 5p
Clock Speed 6MHz
What Should I do ?
Labels
PSoC 5LP
12:57 AM
May 27, 2016
12:57 AM
Welcome in the forum!
Problems like that could best be solved by getting in contact with Cypress directly.: At top of this page select "Design Support -> Create a Support Case" and describe your problem.
Bob
