PSoC® 3 and PSoC 5 vastly simplifies temperature measurement with a thermistor, by providing a component. This implementation is based upon the use of a constant voltage method of thermistor resistance measurement. The application note project gives you practical implementation of temperature sensing using the thermistor component for PSoC® 3 and PSoC 5.
You can find the application note AN66477 can be found at http://www.cypress.com/?rID=49052
