PSoC 5, 3 & 1
PSOC3 datasheet or TRM show internall structure containing analog RC filter using LPF block.
Such block is not available in Psoc Creator. Even thetre are knowledge base article which states there is no such feature available.
What is correct and how set up proper register?
Robert
In fact TRM for CY8C36xxx familly do not contain this info.
But there is also registers TRM, which does.
Robert
