Hello everyone,
I'm an absolute beginner in PSoC Programming and hope someone could help me.
I'm using the PSoC3 on Development Kit, and trying to figure out how I could start the programm with a switch. Normally it starts by supplying.
I want to use both switches, the frist for selecting a special mode. 0 would mean Multiplexer 1 will start, and 1 is for Multiplexer 2. Both are differntial Multiplexers with different "pairs" of signal. After the mode is selected, the second switch should start the programm. It's not neccessary to switch the mode again while the programm is running.
Could anyone help? Or do you have an other solution for this problem?
PSoC 3
Hi Minus,
By Multiplexer, do you mean Analog Multiplexer component available in PSoC Creator?
