PSoC™ 5, 3 & 1
How can i synchronize the speed with which the hardware running on psoc5lp with the speed of execution of code?
Is it possible to synchronize without using ISR?
Thank you.
Bob_Marlowe
Expert II
Usually it is easier to sync the hardware to the CPU using control register writes etc. What exactly do you need to perform?
Bob
I wanted to read the SR flip flop only once when its changing state.
Bob_Marlowe
Expert II
I see no other choice than interrupt.
Bob
Thanks Bob
