Hi, I'm helping to develop a device driver for a module that uses the CY8C9560A. I'm having a problem getting PWM to send a signal. The data sheet isn't very clear to me regarding the exact steps or sequence that needs to be taken to activate PWM for a pin. The code I'm using is below but all I am getting is a solid 1.63V output from PWM8. Can you help point out what I might be missing?
From some of the other posts, I gathered that it might be necessary to reset the device before the PWM settings take effect. Is this the case? Is there a way to soft reset this device? If this is necessary then is there a way to reset just the one pin so that others are not interrupted? Thanks!
io60p16.SetPwm(7, 0, 0x5e, 0x2f); // Port 7, pin 0 = PWM8
public void SetPwm(byte port, byte pin, byte period, byte pulseWidth) { WriteRegister(0x18, port); // Select port var b = ReadRegister(0x1a); b &= (byte)(~(1 << pin)); WriteRegister(0x1a, b); // select PWM for port output b = ReadRegister(0x1C); b &= (byte)(~(1 << pin)); WriteRegister(0x1C, b); // Set pin for output. WriteRegister(0x28, (byte)(0x08 + pin)); // Select the PWM pin to configure. WriteRegister(0x29, 0x00); // Config PWM (select 32kHz clock source) WriteRegister(0x2a, period); // set the period (0-256) WriteRegister(0x2b, pulseWidth); // set the pulse width (0-(period-1)) }
Can it be that you write a 0 (zero) into the PWM-Register 0x1a instead of a 1 (one) as the datasheet tells?
Bob
Bob
I think you're right, Bob. Copy & paste error. I'll give that a try tonight. Thanks!
Ian,
if it's that easy to help, you're always welcome!
Bob
If you're intending to write a 1 bit, then
is certainly wrong. It writes a 0 on the selected pin. Try this code if you want to set the selected bit to 1:
b |= (byte)(1 << pin);
This is another case where I would strongly suggest to use macros for such simple (but easy targets for typos) jobs.
#define BitMask(BitNumber) (0x01 << BitNumber)
#define SetBit(Variable,BitNumber) (Variable |= BitMask(BitNumber))
#define ClearBit(Variable,BitNumber) (Variable &= ~BitMask(BitNumber))
#define GetBit(Variable,BitNumber) (Variable & BitMask(BitNumber))
The original line
would then read
ClearBit(b,pin);
and the line
would become
SetBit(b,pin);
which (in my opinion) is far more readable than the original and thus (even if you cut & paste) would have avoided an error like this inherently.
Bob
(hope I made no Typos)
