PSoC 5, 3 & 1
Bob_Marlowe
Expert II
This is a double post, in PSoC-Software nobody could answer my quest.
In PSoC Creator 2.0 it is possible to set a breakpoint that stops execution when a variable is accessed, read from or written to. The variable is given by its name and the debugger calculates its physical address (I presume).
When debugging a PSoC3 project I try to set a watchpoint to an address in xdata, but till now I failed with that.
Can anybody direct me how to set a watchpoint for a hex-address in xdata?
Bob
Hi Bob,
not much luck so far. Hope you will find a C-specialist soon. Push-Up
