Sending two bytes of consecutive data from SRAM to UART using DMA
hi,
I am able to transfer one byte of data from SRAM to UART, but unable to send more than one byte. I have change bytes per burst to 2 and TD Transfer count to 2 in order to send two bytes of data to serial terminal,but i am getting only 1 byte at Serial terminal. I checked the example code too, but still could not figure out the problem. How can i resolve this issue?
Thank you
