Select Debug Target
I am fairly new to the PSoC community. I am working on a CYC8KIT-059 and I recently came into a problem that I cannot resolve.
Whenever I try loading a program onto the chip using the "program" button on PSoC Creator 3.3 a window pops up that says "select debug target" and the list is empty. Also, the USB status light (LED 3) does this slow, pulsing blink. This is the second board that this has happened to after previously having no problems with a different board.
I've read some topics dealing with this type of problem on the PSoC 4 that seem to point to the bootloader, but I'm not sure how to correct the problem.
Any advice would be greatly appreciated.
Bob_Marlowe
Level 10
Level 10
You are in a different programming mode, press the switch for more than 5 seconds, blinking should change.
Your -059 has no bootloader, but the programming part has one. I would suggest you to update the KitProg to latest version:
Close Creator
Start PSoC Programmer 3.24.4 (update first, when you have got a lower version)
Select your KitProg. There could be a message (after a while) popping up telling you to update firmware. Do as advised.
Close Programmer
Unplug -059, count to 27 and re-plug
Wait for new drivers installed
Start creator
Happy coding
Bob
Dear Bob,
I am new to PSoC and want to start development using PSoC 5LP(I dont want to use PSoC 4 BLE module, hence I have removed it from the board)
I am using CY8CKIT-042-BLE  Pioneer Kit, when I try to program the kit I receive following dialog box
As I cannot expand the box and find PSoC 5LP, therefore I am not able to connect it and program or debug.
I am using PSoC creator 4.0 and  PSoC programmer 3.25.0 and i have updated the firmware but still no joy.
Please Help
Bob_Marlowe
Level 10
Level 10
You cannot do PSoC5 development with a CY8CKIT-042 without a MiniProg3. Best is to buy a CY8CKIT-059.
Bob
Thanks for the quick response
