My first CY8CKIT-050B recognizes by programing not the correct CPU. In place of correct CPU type ... only Cortex-M3 and the .... message ... This device was recognized, but PSoC Creator does not support using it at this time ... Info ... This target device is already in use by another client.
My second CY8CKIT-050B works on the same PC and same conditions OK.
Any help?
Viktor
PSoC 5LP
problem reproduced but not solved. By programming PSoC 5LP needs for recognizing correct CPU Master Clock and Bus clock RUNNING. By using external digital OCXO clock signal you need to configure Cy_Pins Version 1.80, Digital Input, HW Connection, Show External Terminal and Input declared as "TRANSPARENT" in any case NOT "DOUBLE_SYNC".
Is there a solution to REVERT once programmed the input pin as DOUBLE_SYNC to TRANSPARENT.
In other words .... General PSoC 5LP chip erase method to factory default state by software or hardware methods ????
Viktor
Open PSoC Programmer. Up top there's an option "Erase Flash." This will erase the PSoC, like you asked, and fix the faulty clock problem.
Erased flash, converted back to internal clock, same result,
still part ID not recognized.
Regards, Dana.
I once had a similar error which was related to leftovers from a de-install. I filed a case and after 3 days got help with a program that analyzed my registry and deleted wrong entries. All under the help of Cypress.
Bob
Bad USB cable.
Regards, Dana.
