PSoC 5, 3 & 1
Hi everybody,
I found this document: http://www.cypress.com/file/144696/download and I am trying to implement it on a PSOC5. It looks like the documentation of a code example.The document refers to files like main.c for the code and further explanation.
Unfortunately, I can not find the project files anywhere (like with the included code examples) and a search on the cypress homepage was no success either.
Can anybody help me?
Cord
rola_264706
Honored Contributor II
Here is a program that may give you some ideals. I set it up to work on the PSOC 5lp. It was setup for the psoc 3. If this is of no help then you should open a case.
Hi Bob,
thank you for the files, I'll have a look at them.
The customer support could help me, the files are in the Knowledge Base: http://www.cypress.com/knowledge-base-article/frequency-measurement
