09:29 AM
Nov 23, 2011
09:29 AM
Could I use DMA for read a 16 bit data from a master SPI and transfer the data on two 8 bit control registers?
Since the SPI works at very low frequency (1MHz), I need to update both registers only at the end of the reading procedure.
It is enough only one DMA channel or the procedure requires two different transfers ( SPI->RAM, RAM->control register), thus two DMA channels?
Thanks in advance
Labels
PSoC 5LP
11:54 AM
Nov 23, 2011
11:54 AM
I think there was(is? but I couldnt find it.Maybe one of the employees can direct you to it) appnote on SPI with DMA.I'm not entirely sure,but I faintly recall there was one.
02:34 AM
Nov 24, 2011
02:34 AM
02:35 AM
Nov 24, 2011
02:35 AM
