I posted my question in the other forum but got no answer.
The problem was I 'm trying to make 2 PSoC chip communicate via SPI.
PSoC5LP as master and the PSoC4 as slave.
The problem is, MISO line (P0_2) of the PSoC5 seem to pull the pin low.
I have change the pin to P3_0 and everything works as expected.
Can anyone explained what happened?is P0_2 (Opamp ) input cannot be buffered?
Thank you.
PSoC 5LP
Probably you are working with some development kits. To help you more, will you please tell us exactly which?
The pins do not differ in their behaveour but on a Kit they could have some connections. Did you try to program your pin P0_2 and measure to see if it is ok?
Bob
You are correct, i am using CY8KIT-050.
According to the schematic pin P0_2 doesn't seem to be connected to any other hardware except to the header.
Fine that you checked that, now you should try to check P0_2 for any damage.
Bob
When you set up the pin what did you pick for initial state ? A "0" or a "1" ?
The initial state is 0, as I mentioned before it seem like the pin is pull low.weird...
I test the pin as analog output and then as digital output , everything seem to be working.
P2[0] is also tied to LCD data pin thru a 10K R, maybe thats what
you are seeing ?
The pin is P0_2 not P2_0
Do you use any other component, lika the SAR ADC or OpAmps? P0[2] has some predefined functions, maybe they get used somewhere...
nope..just as SPI Master...and P0_2 as MISO line
Strange. Can you use P0[2] as normal GPIO port (just assign a digital out pin to it which you toggle manually e.g. once per second, or maybe just as PWM output or so)?
Strange indeed ...I will test other functions (digital out/In).
Perhaps the pin was damaged somehow
