PSoC 5, 3 & 1
 What is SPC command?
I could find SPC for the flash access. Where do I find the registers related to it?
 SPC is System Performance Controller. It is basically a Master who can write the data into Flash. Registers related to SPC are more of confidential. But you can find some amount of information in the Device Programming Specifications TRM.
ETRO_SSN583
Esteemed Contributor
They are covered in Register TRM -
http://www.cypress.com/?id=2233&rtID=117
Regards, Dana.
