PSoC™ 5, 3 & 1
 Hello
I have some doubts about how use the smp pin, for example how calculate the components used to create the boost and if is posibble use the voltage generated to  feed  the rest of the circuitry and components.
Bob_Marlowe
Expert II
At top of this page is a search field. When entering "SMP" or "switch mode punp" you'll get a handfull (or more) links to documents describing the SPM in detail. www.cypress.com/
Bob
Bob_Marlowe
Expert II
Bob
 thanks bob i will check it
