PSoC 5, 3 & 1
Hi all,
          I'm new to PSoC family,previously i used Freescale and Microchip controller for programming.
                      In PSoC I want to do multichannel ADC conversion and i want to do each 3 ADC channel conversion within the ISR of timer for 1msec.For design this i used one 9 channel multiplexer and 1 delta sigma ADC.I also used 1 timer.In codding i want to do generate a timer interrupt for every 1msec  and in the ISR of Timer i want to do ADC conversion and some other calculation.
Can you please suggent me which type of timer i have to use and how to generate 1msec of delay.
With regards,
          san2884
I'm using PSoC 3 family CY8C3866AXI-040 controller.
Again i have a doubt that for generating 1 msec or more,shall i go for timer or PWM.Please suggest me
     With regards
     san2884
Hi san2884,
You can either use PWM or Timer to generate 1ms Interrupt. The picture below shows how to do it using PWM. Configure PWM for a Period of 99. Connect an input Clock and configure it to give a fequency of 100 Khz. The terminal count output goes high after 1ms. Connect an ISR from system resources and configure the ISR to be triggered on rising edge.
