PSoC™ 5, 3 & 1
Hi All,
Here is an example project on how to implement a re-triggerable mono-stable multivibrator using datapath in PSoC 3/5.
Bob_Marlowe
Expert II
Good idea! But a bit few (none) documentation, so I could not find out how to set the pulse width in design or by program.
Bob
Bob_Marlowe
Expert II
Bob
Good stuff.
I think the pulse width is controlled by the clock. How many clock cycles is the pulse width?
HeLi_263931
Honored Contributor II
When I looked as the datapath configuration tool in the right way, its 100 clock pulses:
  • the component is using the Count7 functionality
  • it is counting down
  • the counter is reloaded, on triggering, from register D0
  • and D0 gets 8'd100 as initial value (and there is no place where it is changed)
