PSoC 5, 3 & 1
PaSv_1652016
New Contributor II
Hello
From (Connections on Vcca and Vccd Pins of PSoC 3 and PSoC 5LP - KBA83234 )
This document says that I should "Connection1:  In this case, both Vccd pins should be connected together with shortest possible route on the PCB, preferably under the PSoC chip."
but I mistakenly didn't make a PCB route shorted Vccd1 and Vccd2 together. My  project work now without  shorted Vccd1:Vccd2
What is this fraught with ? can this affect EMC immunity?
Alakananda_BG
If Vccd1 and Vccd2 are not shorted it may or may not effect the EMC immunity.
Following the hardware guidelines will ensure better EMC immunity.
Please go through the hardware design guidelines in the below link
https://www.cypress.com/file/44581/download
Alakananda
Alakananda
Alakananda_BG
Alakananda
Alakananda
