PSoC 5, 3 & 1
PSoC Creator has an option to export to other IEDs like, IAR Work Bench. Before exporting the project, make sure of the following settings in .cydwr  file, Systems tab ;
1.  Enable Error Correction Code (ECC) is checked.
2. Store Configuration data in ECC Memory is unchecked.
This is because the configuration in ECC memory will not get written and HW will not be set up correctly.
Keerthi
