Hello every one!!!
Have any of you tried to program a Schmartboard whit CY8C3866LTI-030?
I need to test a prototype and I do not want to use the CY8CKIT-030 and have decide to buy a Schmartboard.
I cannot figure out how to download the bootloader project in such a board using the Miniprog3 kit.
The application note PSoC® 3 and PSoC 5LP I2C Bootloader ( AN 60317) explain how to download a bootloadable project using Miniprog 3. It assume that you have a bootloader project already downloaded into the Psoc device, in this case, the CY8C3866LTI-030 on Scmarboard.
In summary, may be someone can explain me how to download a Bootloader project in the Scmarboard sponsored By Cypress.
The readme file provided for Scmarborads, explaning how to program the board is not very explanatory for me.
I have attached the Readme file.
I will appreciate a lot your help.
Thank you very much.
You probably want to overwrite the already programmed bootloader on your schmartboard with your own bootloader. Am I right?
So you first have to create a BootLoader progect. Connecting your miniprog3 to the board and using Creator will work to program that bootloader.
Your BootLoadable project MUST refer to your Bootloder (in "Dependencies" dialog) to get the correct entry-points. Use at first try simple projects that is able to indicate successful bootloader running and bootloadable running. The bootloadable is transfered to your schmartboard with the Cypress program "Bootloader Host".
Bob
Some bootloader references -
http://www.cypress.com/?rID=50230 AN68272 UART BL PSOC 3, 4, 5LP
http://www.cypress.com/?rID=41002 AN60317 I2C BL PSOC 3, 5LP
http://www.cypress.com/?rID=57561 AN73503 USB HID BL with GUI Host PSOC 3, 5LP
http://www.cypress.com/?rID=56014 PSoC® 3, PSoC 4, and PSoC 5LP Introduction To Bootloaders
http://www.cypress.com/?rID=83293 AN86526 - PSoC® 4 I2C Bootloader
http://www.cypress.com/?rID=50230 AN68272 - PSoC® 3, PSoC 4 and PSoC 5LP UART Bootloader
Regards, Dana.
Thank you Bob !!!! and Dana too !
Bob your explanation made me join all information from the App. Notes suggested by Dana.
I am starting from the scratch, in oder words I have purchased the Scmarboard 710-0008-01 unpopulated .
As far as I known any chip, in this case CY8C3866LTI-030 doesn't came wiht a bootloader project already programmed.
I have purchased CY8C3866LTI-030 chip separately.
I have soldered the chip on the Shcmartboard.
Then, it raise the following question: How I need to interpret your explanation about program the bootloader project for first time?
As alway you explanation is awesome !!!!
Best regards.
In Creator either use example BL project or design your own, build and compile it,
and program via Miniprog3. Note the BL is for field updates, as well as people who
do not have a Miniprog3. The advantage of the latter, unlike BL, is that you can debug
your project as well, which you cannot easily do with a BL approach. The latter can be
done with effort by, for example, using a UART and PC and pass your own generated
debug info to the PC for display. But thats very tedious and leaves behind the Creator
debugger GUI that is very efficient and capable.
Regards, Dana.
Hi Dana thank you for your answer.
I have a new question.
Suppose I decide to develop my own PCB and get my prototype already assembled with let say the CY8C3866AXI-040 chip.
Suppose too that my code work Ok on a DVK.
At that point , how am I supposed to program the first time the on board's CY83866AXI-040 without use a production programer?
I am refering to the first tests before production with that PCB, to test it.
Thank you again and I'll be waiting for you explanation, I do not master the English languaje and may be I am missing something about your last explanation.
Best regads,
Take a look at this -
and this based on use of FX2 parts -
http://dangerousprototypes.com/2011/10/30/psoc3-custom-board/
Regards, Dana.
Thank you very much Dana !
When you have got a MiniProg3 then the easiest way to program any PSoC-pcb is to access the ISSP pins on a connector suitable for plugging-on the Miniprog. This does allow for programming but not for debugging. Three signals are needed üöus power, one of them is xres, the other two are usually connected to SDA and SCL of I2C and can be used after programming as wanted.
Bob.
Yes, Dana is right. With Miniprog3 you may debug your PSoC 3, 4 and 5 targets.
Bob
Bob and Dana Thank you a lot for your valuable help
Hi Dana !!!
May be you can give me some aditional explanation about yor post that I will repeat here:
"In Creator either use example BL project or design your own, build and compile it,
debugger GUI that is very efficient and capable."
So, if I understood well, I can use either BL project example to progam the device with miniprog 3 and afterward program the bootlodable project as Bob explain me in previous replay?
I am in the stage of testing a prototype using the Scmarboard (not in DVK because on it work OK ), and I can not spent time in modification of the HSSP to Psoc3 Host > Psoc3 traget device.
Thank you very much
Yes, a boot loader will load a bootloadable project w/o a Miniprog3,
over UART or I2C or SPI, there is a myriad of ways it can be done.
The advantage of Miniprog3, is if you are on JTAG or SWD you can program and
debug. If on ISSP just program.
BL on the other hand is for field upgrades typically. Where end user does not own a
Miniprog3 but you have an update for him.
Regards, Dana.
Dana ,Thanks a lot !!!!
