PSoC 5, 3 & 1
Is it possible to program the CY8CKIT-010 family module directly, when it is not on the CY8CKIT-001 board? Looking at the schematic it seems that with power supplied by the programmer (MiniProg3)  this should work, but I haven't had any luck,
Thanks in advance for your help.
AnkitaS_51
Hello ,
If you see the schematic of CY8CKIT-010,you will find that VDDIO1 power being supplied by MiniProg3 via J6.
But VDDD,VDDA,VDDIO1,VDDIO2 and VDDIO3 are not powered.
You may try mounting with 0 Ohm resistor these resistors R14,R15,R16,R17 ,R4,R6 and R7.
