I have an application that is based on a 5LP that requires a programmable power supply for part of the circuit.
The input voltage is fixed between 12V and 24V DC. I need to provide part of the circuit with adjustable voltage from 5V to 9.5V DC (1Amp max).
I am considering using the DAC to op amp and driving the adjut pin of an LM317 but don't really want to need a large heatsink.
I also looked at controlling the feedback of switching regulator IC?
The adjustments do not need to be fine, 16 levels (4 bits) would be fine. I thought maybe I could have 4 x binary weighted resistors in feedback loop of SMPS IC but maybe there is a common way of solving this that you guys have used successfully? Or know of an IC that would accept DAC or binary inputs for control.
Thanks for any suggestions.
PSoC 5LP
TI (now also NSC) have controlled switching solutions, take a look
here (consider contacting their FAE as well) -
www.ti.com/lsds/ti/analog/powermanagement/power_portal.page
Regards, Dana.
Dana,
can you point to a particular part number at TI website?
odissey1
@Orbitcoms,
we used digital pot in the feedback loop of the switching regulator.
odissey1
Just interesting Laboratory Power Supplies (in Russian): PowerSupplyUnit_R_20140916.rar
Excellent demonstrates the capabilities of PSoC)))
Source here.
Here is the digital power supply page of TI -
www.ti.com/lsds/ti/power-management/digital-power-control-solutions-overview.page
Regards, Dana.
