Power Cycle Mode
roni_2595911
It is possible to proggram a PSOC 1 Power Cycle mode, where this device has XRES pin floating?
I received a PCB with CY8C21334B-LXI but this board has only Vdd, SCLK, SDAT, and Vss available trough Test Points, XRES is not routed to anything,
*I have MiniProg3 that actually supports ISSP
What conditions need to be meet in order to Acquire Chip and proggram it?
Thanks in advance
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
You can set the "Programming Mode" to "Power Cycle" in PSoC Programmer, and then the CY8C21334B-LXI can be acquired and programmed.
Sampath Selvaraj
SampathS_11
Sampath Selvaraj
