PWM output as clock for Counter on PSoC 5LP??
MaWo_1214996
First like given
I am using a PWM component to generate a signal around 40 kHz on one pin.
However, I don't need a continuous signal, I need instead a signal every minute or so (triggered by software) of only 1-32 pulses.
Now I wanted to use a counter and use the PWM signal a trigger for the counter, but the counter doesn't like the signal as clock input.
What I can do about it?
Mark
Bob_Marlowe
Level 10
Level 10
Just configure the counter as UDB and use it as in the attached picture.
Bob
MaWo_1214996
First like given
Thanks, Bob, this was what I am looking for, will try it out...
Mark
Bob_Marlowe
Level 10
Level 10
You are always welcome, Mark.
Bob
