PSoC 5, 3 & 1
CaDu_3933941
New Contributor II
Hi all,
I am currently working in building an RC car for which I am going to require 2 PSoC 5LPs. I have already built the motor controller, now I will be moving onto the PSoC to PSoC communication. I have found a couple Bluetooth modules online:
Bestgle HC-05 6 Pin Wireless Bluetooth RF
So I just wanted to know if this module would be good enough for PSoC to PSoC communication. I need to be able to send at least 8 bit values for motor speed control.
odissey1
Honored Contributor II
molinac,
HC-05 Bluetooth is good for connecting to phone, tablet or PC, but usually needs a lot of code and libraries. Not sure if it is possible to do direct HC-05 to HC-05 communication easily. Probably, a transceiver is needed like this one (NRF24L01):
2PCS,Arduino NRF24L01+ 2.4GHz Wireless Transceiver Module New 772640059747 | eBay
Or this one:
CC1101 Wireless RF Transceiver 315/433/868/915MHZ + SMA Antenna Wireless Module 870999698188 | eBay
There are many tutorials using NRF24L01, see:
https://www.instructables.com/id/Getting-Started-With-NRF24L01-Wireless-Transceiver/
And PSoC components:
Re: nRF24 Custom Component
/odissey1
odissey1
molinac,
Or this one:
/odissey1
