PSoC 5, 3 & 1
Dear Cypress engineers:
          I have a question about  the psoc creator error,it remind me that:
dbg.M0015:Debugger exited unexpectedly during run.Encountered error (Program exited with error :MP3_ERROR)
How can i deal with the problem? please let me know the answer as soon as possible,thanks!
Bob_Marlowe
Expert II
did you change the clocks or did you use sleep or hybernate?
This will / can disconnect the debug-session.
Bob
Hello Bob :
Thanks for you reply, I  also think there are some problems about clock setting in my project, i had modified the clock under the USB clock settings guide,and there was no errors in building process,but when debuging the project ,the error appeared!
PS:An ADC conponent and a USB component are included in my project!
hi Jacktan,
i haven't encountered such an issue before.
can you attach the project in which you were facing this issue?
Do you have a watchdog runnning?
Hi:
Project's .sch design and clock setting is attached for you reference,
I had used the watchpoint during the debugging process!
Thanks and best regards!
attach file!
