I create an example project about USBFS UART for cy8ckit-059 and I want to know why my laptop can't detect the device when development board is connected to the laptop via micro usb.
ispn:39618:1:0
l1:314:1:0
I downloaded your project and rebuilt, program the board.
You may want to check if your USB-microB cable is battery charge only
or supporting USB communication.
moto
I downloaded your project and tried on my Windows10 (Japanese) PC.
And my PC could detect my CY8CKIT-059
(1) When both USB-A and USB-microB are connected
(2) When only micro-B is connected
(3) I could type COM18 (USB Serial)
But thanks for the CyDelay() and LED, the response was painfully slow.
When I commented out line 87, 88, and 184 of main.c,
response got acceptable.
Meantime, whe I read the USBFS_UART.pdf, I noticed that this program
requires Tera Term Serial Setting as
Baud Rate: 115200
Data: 7 bit
Parity: even
Oh, One thing I should have mentioned is that to let the PC detect the USB CDC of micro USB,
we need to let the program run for a while, around the main loop.
moto
Did you download or write other application or driver for cy8ckit-059 in your PC?
I connect to my laptop via micro usb and nothing change on the Device Manager.
moto
