PSoC 5, 3 & 1
CaDu_3933941
New Contributor II
Hi all,
For my current project, I require to be able to read the pulse width of a PWM signal and store it in a variable using a PSoC 5LP. I would appreciate the help if anyone offered me any method on how to do this efficiently.
MotooTanaka
Esteemed Contributor
It took me a few days to implement this with CY8CKIT-059.
There may (must) be better strategies, but this is the way I made it.
At first I was trying to implement a state machine which advances state in each edge of the input signal,
after all, I could not make it work well. (May be I'll try it again someday)
Then I changed my strategy to use a couple of counters,
one for counting "High" level and the other for "Low" level.
With Rising Edge of the input signal,
High Level counter gets reset and start counting,
Low Level counter gets "capture" signal
With Falling Edge of the input signal
High Level counter gets "capture" signal
Low Level counter gets reset and start counting.
The schematic seems as
companion schematics
Test PWM signal Generator
UART as usual
Pin Assignment
main.c
* Duty Cycle Count Test
#include "project.h"
#include "stdio.h"
volatile uint16_t h_count = 0 ;
volatile uint16_t l_count = 0 ;
char str[128] ; /* print buffer */
void print(char *str)
    UART_PutString(str) ;
void splash(void)
    sprintf(str, "Duty Cycle Count Test (%s %s)\n", __DATE__, __TIME__) ;
    print(str) ;
CY_ISR(isr_H_callback)
    h_count = H_Counter_ReadCapture() ;
    isr_H_ClearPending() ;
    H_Counter_Enable() ;
CY_ISR(isr_L_callback)
    l_count = L_Counter_ReadCapture() ;
    isr_L_ClearPending() ;
    L_Counter_Enable() ;
void config_pwm(uint16_t period, uint16_t compare)
    PWM_Stop() ;
    PWM_WriteCounter(0) ;
    PWM_WritePeriod(period) ;
    PWM_WriteCompare(compare) ;
    PWM_Start() ;
void init_hardware(void)
    Control_Reg_Write(1) ;
    CyDelayUs(10) ;
    Control_Reg_Write(0) ;
    UART_Start() ;
    H_Counter_Start() ;
    L_Counter_Start() ;
    isr_H_StartEx(isr_H_callback) ;
    isr_L_StartEx(isr_L_callback) ;
    CyGlobalIntEnable; /* Enable global interrupts. */
void print_duty(uint16_t period, uint16_t compare)
    uint16_t LW, HW ;
    float duty ;
    LW = l_count ;
    HW = h_count ;
    sprintf(str, "PWM %d/%d ", compare, period) ;
    print(str) ;
    sprintf(str, "Duty = %d:%d ", HW, LW) ;
    print(str) ;
    duty = (float)HW / (float)(HW + LW) ;
    sprintf(str, "%d.%02d %%\n", (int)(100 * duty), (int)(10000 * duty) % 100) ;
    print(str) ;
    uint16_t period = 10000 ;
    uint16_t compare = 5000 ;
    init_hardware() ;
    splash() ;
    config_pwm(period, compare) ;
    CyDelay(1000) ;
    for(;;)
        print_duty(period, compare) ;
        compare += 100 ;
        if (compare > period) {
            compare = 0 ;
        CyDelay(1000) ;
Tera Term Log
I'm glad that it's Friday!
moto
BoMa_4329931
New Contributor II
Have a look into this thread.
Bob
MotooTanaka
UART as usual
Pin Assignment
main.c
#include "stdio.h"
void splash(void)
    print(str) ;
    PWM_Stop() ;
    PWM_Start() ;
    CyDelayUs(10) ;
    UART_Start() ;
    H_Counter_Start() ;
    L_Counter_Start() ;
    uint16_t LW, HW ;
    float duty ;
    LW = l_count ;
    HW = h_count ;
    print(str) ;
    print(str) ;
    print(str) ;
    init_hardware() ;
    splash() ;
    CyDelay(1000) ;
    for(;;)
        compare += 100 ;
            compare = 0 ;
        CyDelay(1000) ;
Tera Term Log
moto
