Good to see all the source code examples for the various PSOCs.
Are the C source code examples which are based on Arm Cortex M-series
PSOC cores compatible with each other ?
I am reading through some of the SPI/DMA examples for a PSOC5 target
and was wondering how compatible the different PSOC examples are.
PSoC 5 Device Programming
PSoC 5LP
Hello
Thank you for the interest in our code examples. Between PSoC5, PSoC4 and PSoC 6 there are difference in the DMA and SPI (SCB SPI) architecture. So the project would not be directly compatible. If you check the PSoC Creator Code Example section you can find examples specific to the product families.
Hima
Hello
Hima
