wiyu_4570436
I create a project to measure the frequency of a 500kHz-600kHz square wave per 100us as below. But the result is very unstable varying form 400kHz - 1000kHz.
Anyone has a simple and stable frequency measurement solution?
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
I wonder if my sample at following topic can be a hint
PWM duty cycle + freq measurement
moto
MotooTanaka
Level 9
Level 9
moto
Len_CONSULTRON
Level 9
Level 9
wiyu,
Is the frequency you are trying to measure stable?  The reason I ask, is that you precondition your input with a divide-by-20 frequency divider.  Any frequency fluctuations will be averaged across 20 input cycles.
If you share your project, I will try to reproduce your results.
Len
Len
