PSOC 3 counter one-shot
JoBe_296651
The PSOC 3 Counter datasheet states that, for UDB implementation in one-shot mode, the counter will stop at terminal count and reload.  If "Reload on TC" in the configuration window is unchecked, does this prevent reloading in one-shot mode?
ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
Try a quick test by reading  count register when it is stopped, checked
and un-checked.
One of the beauties of PSOC Creator, fast simple self test project generation.
Regards, Dana.
Dana,
I hate to be so ignorant, but can you mention the method by which you read the registers per your instructions?  It sounds really useful, but I am so new at this that everything is a struggle.
Best, Rich
ETRO_SSN583
Level 9
Level 9
If you right click a component, go to its datasheet, there is a section on
APIs that can be used to read/write a components key registers, like
the primary counter in a counter/timer....
Regards, Dana.
