PSoC™ 5, 3 & 1
HI.
Sorry but my english is little, and I started witch psoc ...    how to correctly read data from pcf8583 ???
#include "project.h"
#include "tm1637.h"
//#define PCF8583_ADDR 0xA0        // gdy A1 --> GND
#define PCF8583_ADDR 0xA2        // gdy A1 --> VCC
uint8 czas[4];
uint8 ss=4, mm=3, hh=2, day, month;
int main(void),
    CyGlobalIntEnable; /* Enable global interrupts. */
    I2C_1_Start();
    /* Place your initialization/startup code here (e.g. MyInst_Start()) */
    for(;;)
    SENDnumber(4523);                       //TM1637
    I2C_1_MasterSendStart(PCF8583_ADDR, 0);
    I2C_1_MasterWriteByte( PCF8583_ADDR );
    I2C_1_MasterWriteByte( 0x02 );
    I2C_1_MasterWriteByte( PCF8583_ADDR+1);
    ss = I2C_1_MasterReadByte(I2C_1_ACK_DATA);
    mm = I2C_1_MasterReadByte(I2C_1_NAK_DATA);
    I2C_1_MasterSendStop();
        SENDnumber( ss);
           CyDelay(500);
        SENDnumber( mm );
           CyDelay(500);
         SENDnumber( hh );
           CyDelay(500);
    to check i2c function i used led and variable ct but the max val is 1 😕
for(;;)
SENDnumber(ct++);                   //TM1637
AnkitaS_51
Please see the mikroC-AVR     for RTC read and write
