PSoC 5, 3 & 1
gubac_1268471
New Contributor II
I am trying to run the USBFS_UART01 example for a CY8C5868AXI-LP exactly as it was generated by the development environment from the list of available examples.
I work under Windows 10.
I use my card and a MiniProg3 to program it.
At the first attempt to program the microcontroller, I obtained the following results.
The programming connector is connected, the card is powered, on the MiniProg3 only the "Target power" light is on, while all the others are off and the microcontroller is not recognized.
I also tried using the JTAG protocol, obtaining the same result.
The configuration of the development environment is as follows.
Environment:
PSoC Creator  4.2 (4.2.0.641)
Culture: Italian (Italy)
OS Version: Microsoft Windows NT 10.0.17134.0
CLR Version: 4.0.30319.42000
Installed CyInstaller Products:
CY8CKIT-002 MiniProg3 1.0 Rev**
Cypress Document Manager 1.0 SP1
Peripheral Driver Library 3.0.1
PSoC Programmer 3.27.1
PSoC Creator 4.2
Loaded Plugins:
Version: 4.2.0.641
Company: Cypress Semiconductor
Description: Loads component customizers.
Name: Addin Discovery
Version: 4.2.0.641
Description: Discovers PSoC Creator addins (kits, language packs, etc)
Version: 4.2.0.641
Description: Device Catalog Plugin
Version: 4.2.0.641
Description: Adds the topics available in the documentation.
Version: 4.2.0.641
Description: Adds a start page to the framework.
Name: Output Window Plugin
Version: 4.2.0.641
Description: Adds the output window
Version: 4.2.0.641
Description: The Source Code Control Manager is the central class used for SCC actions within PSoC Creator.
Name: Symbol, Schematic and SchMacro Factory
Version: 4.2.0.641
Description: The Symbol and Schematic Factory is used to load, cache, and retrieve symbols and schematics.
Name: Project Manager Plugin
Version: 4.2.0.641
Description: Adds project management related functionality.
Version: 4.2.0.641
Description: Loads the Symbol and Schematic editors
Version: 4.2.0.641
Description: Supports user files in multiple languages
Version: 4.2.0.641
Description: The Workspace Factory is used to retrieve instances of PSoC Creator workspaces.
Version: 4.2.0.641
Description: The Project Factory is used to retrieve instances of PSoC Creator projects.
Version: 4.2.0.641
Description: PSoC Creator Toolchain Manager
Name: ARM GCC Generic
Version: 4.2.0.641
Description: ARM GNU Generic
Name: ARM MDK Generic
Version: 4.2.0.641
Description: ARM MDK Generic
Name: ARM IAR Generic
Version: 4.2.0.641
Description: ARM IAR Generic
Name: DP8051 Keil Generic
Version: 4.2.0.641
Description: DP8051 Keil Generic
Version: 4.2.0.641
Description: Adds a dialog that allows the user to select a device.
Name: File Editor Factory Plugin
Version: 4.2.0.641
Description: Add file editors to the framework.
Name: Transport Framework
Version: 4.2.0.641
Description: Provides a generic device communication framework for use by other plugins.
Version: 4.2.0.641
Description: The Core Debugger provides an architecture independent framework for the common debug features.
Version: 4.2.0.641
Description: Provides debugging support for the different PSoC families through a GDB back end.
Version: 4.2.0.641
Description: Provides debugging support for FM device families
Name: Device IO Transport
Version: 4.2.0.641
Description: Provides device IO support for Cypress devices though PSoC Programmer APIs.
Name: Serial Transport
Version: 4.2.0.641
Description: Provides basic serial device support for the rest of the tool.
Version: 4.2.0.641
Description: Provides a host tool to perform bootloading operations.
Name: Background Elaborator
Version: 4.2.0.641
Description: PSoC Creator Background Elaborator.
Version: 4.2.0.641
Description: The TypeCache Factory is used to retrieve instances of TypeCaches.
Version: 4.2.0.641
Description: PSoC Fitter Plugin
Version: 4.2.0.641
Description: FM Fitter Plugin
Version: 4.2.0.641
Description: Registers resource editors with devices.
Version: 4.2.0.641
Description: Enables quick and correct development of applications that use DMA.
Version: 4.2.0.641
Description: Manages custom component tuner executables
Version: 4.2.0.641
Description: The Notice Window displays notices (status messages / errors with managed lifetimes).
Do you have any advice to give me?
Guido
DheerajK_81
Hello Guido,
Since your CY8C5868AXI-LP kit is not being powered externally, your settings are correct. It should ideally be acquired in both reset and power cycle mode. Anyways, since reset isn't working for you, can you please try Power Cycle mode and select 5V as shown below:
After this, click on Miniprog3 and then you can click on "Port Acquire" as shown below:
You should be able to see the kit detected. Then click on your kit and hit "OK/Connect" to program your device.
Additional information:
1) The red light (target power led) indicates that the Miniprog 3 is providing power to the kit.
2) Design and Programming Checklist for for PSoC® 3/ PSoC 5LP – KBA208166
Dheeraj
